Nightmare trying to install Code Composer Studio
StrongPenguin
Joined Jun 9, 2018
307
I've been struggling with CCS for nearly the whole day. I finally got the bloody thing installed with the offline installer after god knows how many error messages, but now when I try to run this junk, I get the message
and the build just fails.
What can I do? I can't get IAR to work, either. After the trial, I just get a "License something something" message, when I try to compile. I thought there was a 8kB restricted free version, but I can't find it.
rsjsouza
Joined Apr 21, 2014
430
I have been running CCS fine for many years (several versions) and the license is a thing of the past - i.e., it shouldn't affect you if you are using version 7 and newer.
One detail that may be causing trouble is the use of special characters in the path - this tends to cause trouble with many tools (not only CCS).
Perhaps retry with a different user, place the workspace or set the temp directory to a different place (C:\temp)?
