hi,
Since couple of years ago,I've had a custom board using STM32f429 uc . And god bless ST company for nowadays good linux-based IDEs and HAL Cube libraries.
For the instance,I customized a LTDC example of Cube v1.24 lib,STM324x9I_EVAL (SW4STM32 IDE), for my own board to drive a color LCD 7",and it successfully showed the RGB565_480x272 bitmap picture in source code,since I'd chanegd configurations with every details of ltdc protocol for my Board and LCD.
(Configs like LTDC gpio pins,clock,etc and Hsync,Vsync,VBP,HBP,etc for LCD).
for the next step,I made a CubeMX template for my board and generated a code for AC6 (SW4STM32) IDE with exactly the same Cube Library as customized STM324x9I_EVAL... and copied the routines to newly generated code with CubeMX to use STEmwin middleware...
All the Gpio ,clock,ltdc ,etc and routins checked to be the same as previously cusomized code.but...strangely, the LCD shows only mixed color bar codes instead of thorough bitmap picture.and even can't change background color as well.
So,is there any advice except that configs I mentioned to be considered for this nightmare?
STM324x9I_EVAL's customized main code:
and this main code generated by CubeMx:
Code:
* @file LTDC/LTDC_Display_1Layer/Src/main.c
* @author MCD Application Team
* @brief This example provides a description of how to configure LTDC peripheral
* to display BMP image on LCD using only one layer.
* @attention
* <h2><center>© COPYRIGHT(c) 2017 STMicroelectronics</center></h2>
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "RGB565_480x272.h"
/** @addtogroup STM32F4xx_HAL_Examples
/** @addtogroup LTDC_Display_1Layer
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
static void LCD_Config(void);
static void SystemClock_Config(void);
static void Error_Handler(void);
/* Private functions ---------------------------------------------------------*/
* @brief Main program
* @param None
* @retval None
int main(void)
/* STM32F4xx HAL library initialization:
- Configure the Flash prefetch, instruction and Data caches
- Configure the Systick to generate an interrupt each 1 msec
- Set NVIC Group Priority to 4
- Global MSP (MCU Support Package) initialization
SystemClock_Config();
HAL_Init();
/* Configure the system clock to 180 MHz */
/* Configure LED3 */
BSP_LED_Init(LED2);
BSP_LED_Init(LED1);
BSP_LED_On(LED1);
HAL_Delay(1000);
BSP_LED_Off(LED1);
/* Configure LCD: Only one layer is used */
LCD_Config();
Backlight_On();
/* Infinite loop */
while (1)
* @brief LCD Configuration.
* @note This function Configure tha LTDC peripheral :
* 1) Configure the Pixel Clock for the LCD
* 2) Configure the LTDC Timing and Polarity
* 3) Configure the LTDC Layer 1 :
* - The frame buffer is located at FLASH memory
* - The Layer size configuration : 480x272
* @retval
* None
static LTDC_HandleTypeDef hltdc_F;
HAL_LTDC_MspInit(&hltdc_F);
LTDC_LayerCfgTypeDef pLayerCfg;
/* LTDC Initialization -------------------------------------------------------*/
/* Polarity configuration */
/* Initialize the horizontal synchronization polarity as active low */
hltdc_F.Init.HSPolarity = LTDC_HSPOLARITY_AL;
/* Initialize the vertical synchronization polarity as active low */
hltdc_F.Init.VSPolarity = LTDC_VSPOLARITY_AL;
/* Initialize the data enable polarity as active low */
hltdc_F.Init.DEPolarity = LTDC_DEPOLARITY_AL;
/* Initialize the pixel clock polarity as input pixel clock */
hltdc_F.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
/* Timing configuration */
/* Horizontal synchronization width = Hsync - 1 */
hltdc_F.Init.HorizontalSync = 39;
/* Vertical synchronization height = Vsync - 1 */
hltdc_F.Init.VerticalSync = 19;
/* Accumulated horizontal back porch = Hsync + HBP - 1 */
hltdc_F.Init.AccumulatedHBP = 85;
/* Accumulated vertical back porch = Vsync + VBP - 1 */
hltdc_F.Init.AccumulatedVBP = 41;
/* Accumulated active width = Hsync + HBP + Active Width - 1 */
hltdc_F.Init.AccumulatedActiveH = 521;
/* Accumulated active height = Vsync + VBP + Active Heigh - 1 */
hltdc_F.Init.AccumulatedActiveW = 885;
/* Total height = Vsync + VBP + Active Heigh + VFP - 1 */
hltdc_F.Init.TotalHeigh = 543;
/* Total width = Hsync + HBP + Active Width + HFP - 1 */
hltdc_F.Init.TotalWidth = 1095;
/* Configure R,G,B component values for LCD background color */
hltdc_F.Init.Backcolor.Blue = 10;
hltdc_F.Init.Backcolor.Green = 10;
hltdc_F.Init.Backcolor.Red = 20;
hltdc_F.Instance = LTDC;
/* Layer1 Configuration ------------------------------------------------------*/
/* Windowing configuration */
/* In this case all the active display area is used to display a picture then :
Horizontal start = horizontal synchronization + Horizontal back porch = 43
Vertical start = vertical synchronization + vertical back porch = 12
Horizontal stop = Horizontal start + window width -1 = 43 + 480 -1
Vertical stop = Vertical start + window height -1 = 12 + 272 -1 */
pLayerCfg.WindowX0 = 0;
pLayerCfg.WindowX1 = 480;
pLayerCfg.WindowY0 = 0;
pLayerCfg.WindowY1 = 272;
/* Pixel Format configuration*/
pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
/* Start Address configuration : frame buffer is located at FLASH memory */
pLayerCfg.FBStartAdress = (uint32_t)&RGB565_480x272;
/* Alpha constant (255 totally opaque) */
pLayerCfg.Alpha = 255;
/* Default Color configuration (configure A,R,G,B component values) */
pLayerCfg.Alpha0 = 0;
pLayerCfg.Backcolor.Blue = 0;
pLayerCfg.Backcolor.Green = 0;
pLayerCfg.Backcolor.Red = 0;
/* Configure blending factors */
pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
/* Configure the number of lines and number of pixels per line */
pLayerCfg.ImageWidth = 480;
pLayerCfg.ImageHeight = 272;
/* Configure the LTDC */
if(HAL_LTDC_Init(&hltdc_F) != HAL_OK)
/* Initialization Error */
Error_Handler();
/* Configure the Layer */
if(HAL_LTDC_ConfigLayer(&hltdc_F, &pLayerCfg, 1) != HAL_OK)
Error_Handler();
* @brief System and LTDC Clocks Configuration
* The system Clock is configured as follow :
* System Clock source = PLL (HSE)
* SYSCLK(Hz) = 180000000
* HCLK(Hz) = 180000000
* AHB Prescaler = 1
* APB1 Prescaler = 4
* APB2 Prescaler = 2
* HSE Frequency(Hz) = 25000000
* PLL_M = 25
* PLL_N = 360
* PLL_P = 2
* PLL_Q = 7
* VDD(V) = 3.3
* Main regulator output voltage = Scale1 mode
* Flash Latency(WS) = 5
* The LTDC Clock is configured as follow :
* PLLSAIN = 192
* PLLSAIR = 5
* PLLSAIDivR = 4
* @param None
* @retval None
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
/* Enable Power Control clock */
__HAL_RCC_PWR_CLK_ENABLE();
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/*##-1- System Clock Configuration #########################################*/
/* Enable HSE Oscillator and activate PLL with HSE as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 25;
RCC_OscInitStruct.PLL.PLLN = 360;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
/* Activate the Over-Drive mode */
HAL_PWREx_EnableOverDrive();
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
/*##-2- LTDC Clock Configuration ###########################################*/
/* LCD clock configuration */
/* PLLSAI_VCO Input = HSE_VALUE/PLL_M = 1 MHz */
/* PLLSAI_VCO Output = PLLSAI_VCO Input * PLLSAIN = 192 MHz */
/* PLLLCDCLK = PLLSAI_VCO Output/PLLSAIR = 192/5 = 38.4 MHz */
/* LTDC clock frequency = PLLLCDCLK / LTDC_PLLSAI_DIVR_4 = 38.4/4 = 9.6 MHz */
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC;
PeriphClkInitStruct.PLLSAI.PLLSAIN = 300;
PeriphClkInitStruct.PLLSAI.PLLSAIR = 4;
PeriphClkInitStruct.PLLSAIDivR = RCC_PLLSAIDIVR_2;
HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
* @brief This function is executed in case of error occurrence.
* @param None
* @retval None
/* Turn LED3 on */
BSP_LED_On(LED2);
while(1)
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Code:
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* <h2><center>© Copyright (c) 2019 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
LTDC_HandleTypeDef hltdc;
SDRAM_HandleTypeDef hsdram1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_GPIO_Init(void);
static void MX_FMC_Init(void);
static void MX_LTDC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_FMC_Init();
MX_LTDC_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
HAL_GPIO_TogglePin(LED_B_GPIO_Port,LED_B_Pin);
HAL_Delay(1000);
HAL_GPIO_TogglePin(LED_G_GPIO_Port,LED_G_Pin);
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
clocks dividers */
* @brief LTDC Initialization Function
* @param None
* @retval None
__HAL_RCC_LTDC_CLK_ENABLE();
/* USER CODE BEGIN LTDC_Init 0 */
/* USER CODE END LTDC_Init 0 */
LTDC_LayerCfgTypeDef pLayerCfg ;
/* USER CODE BEGIN LTDC_Init 1 */
/* USER CODE END LTDC_Init 1 */
hltdc.Instance = LTDC;
hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
hltdc.Init.HorizontalSync = 39;
hltdc.Init.VerticalSync = 19;
hltdc.Init.AccumulatedHBP = 85;
hltdc.Init.AccumulatedVBP = 41;
hltdc.Init.AccumulatedActiveW = 885;
hltdc.Init.AccumulatedActiveH = 521;
hltdc.Init.TotalWidth = 1095;
hltdc.Init.TotalHeigh = 543;
hltdc.Init.Backcolor.Blue = 250;
hltdc.Init.Backcolor.Green = 250;
hltdc.Init.Backcolor.Red = 20;
if (HAL_LTDC_Init(&hltdc) != HAL_OK)
Error_Handler();
pLayerCfg.FBStartAdress = 0;
pLayerCfg.ImageWidth = 0;
pLayerCfg.ImageHeight = 0;
pLayerCfg.Backcolor.Blue = 50;
pLayerCfg.Backcolor.Green = 50;
pLayerCfg.Backcolor.Red = 100;
if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN LTDC_Init 2 */
/* USER CODE END LTDC_Init 2 */
/* FMC initialization function */
FMC_SDRAM_TimingTypeDef SdramTiming;
/** Perform the SDRAM1 memory initialization sequence
hsdram1.Instance = FMC_SDRAM_DEVICE;
/* hsdram1.Init */
hsdram1.Init.SDBank = FMC_SDRAM_BANK2;
hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_8;
hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_12;
hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3;
hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2;
hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_ENABLE;
hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_0;
/* SdramTiming */
SdramTiming.LoadToActiveDelay = 2;
SdramTiming.ExitSelfRefreshDelay = 7;
SdramTiming.SelfRefreshTime = 4;
SdramTiming.RowCycleDelay = 7;
SdramTiming.WriteRecoveryTime = 3;
SdramTiming.RPDelay = 2;
SdramTiming.RCDDelay = 2;
if (HAL_SDRAM_Init(&hsdram1, &SdramTiming) != HAL_OK)
Error_Handler( );
* @brief GPIO Initialization Function
* @param None
* @retval None
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOE_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOI_CLK_ENABLE();
__HAL_RCC_GPIOF_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOJ_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOK_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(W25_Flash_CS_GPIO_Port, W25_Flash_CS_Pin, GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOC, LED_B_Pin|LED_G_Pin, GPIO_PIN_RESET);
HAL_GPIO_WritePin(Buzzer_GPIO_Port, Buzzer_Pin, GPIO_PIN_RESET);
HAL_GPIO_WritePin(DCMI_Power_Down_Mode_GPIO_Port, DCMI_Power_Down_Mode_Pin, GPIO_PIN_RESET);
HAL_GPIO_WritePin(LCD_Backlight_GPIO_Port, LCD_Backlight_Pin, GPIO_PIN_SET);
/*Configure GPIO pin : W25_Flash_CS_Pin */
GPIO_InitStruct.Pin = W25_Flash_CS_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(W25_Flash_CS_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : PE4 PE5 PE6 */
GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Alternate = GPIO_AF13_DCMI;
HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
/*Configure GPIO pin : PI9 */
GPIO_InitStruct.Pin = GPIO_PIN_9;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF9_CAN1;
HAL_GPIO_Init(GPIOI, &GPIO_InitStruct);
/*Configure GPIO pins : LED_B_Pin LED_G_Pin */
GPIO_InitStruct.Pin = LED_B_Pin|LED_G_Pin;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/*Configure GPIO pin : Buzzer_Pin */
GPIO_InitStruct.Pin = Buzzer_Pin;
HAL_GPIO_Init(Buzzer_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : PH3 */
GPIO_InitStruct.Pin = GPIO_PIN_3;
GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
/*Configure GPIO pin : SW3_Pin */
GPIO_InitStruct.Pin = SW3_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
HAL_GPIO_Init(SW3_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : PA4 PA6 */
GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_6;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/*Configure GPIO pin : POT_Pin */
GPIO_InitStruct.Pin = POT_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
HAL_GPIO_Init(POT_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : SD_CARD_CD_PIN_Pin */
GPIO_InitStruct.Pin = SD_CARD_CD_PIN_Pin;
HAL_GPIO_Init(SD_CARD_CD_PIN_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : PH12 */
GPIO_InitStruct.Pin = GPIO_PIN_12;
/*Configure GPIO pins : PB14 PB15 */
GPIO_InitStruct.Pin = GPIO_PIN_14|GPIO_PIN_15;
GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/*Configure GPIO pin : DCMI_Power_Down_Mode_Pin */
GPIO_InitStruct.Pin = DCMI_Power_Down_Mode_Pin;
HAL_GPIO_Init(DCMI_Power_Down_Mode_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : SW4_Pin */
GPIO_InitStruct.Pin = SW4_Pin;
HAL_GPIO_Init(SW4_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : PC6 PC7 */
GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
/*Configure GPIO pin : PA9 */
/*Configure GPIO pin : PA10 */
GPIO_InitStruct.Pin = GPIO_PIN_10;
GPIO_InitStruct.Alternate = GPIO_AF10_OTG_FS;
/*Configure GPIO pin : PH13 */
GPIO_InitStruct.Pin = GPIO_PIN_13;
/*Configure GPIO pin : PD3 */
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/*Configure GPIO pins : PG9 PG14 */
GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_14;
GPIO_InitStruct.Alternate = GPIO_AF8_USART6;
HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
/*Configure GPIO pin : PG10 */
/*Configure GPIO pin : LCD_Backlight_Pin */
GPIO_InitStruct.Pin = LCD_Backlight_Pin;
HAL_GPIO_Init(LCD_Backlight_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : PB7 */
GPIO_InitStruct.Pin = GPIO_PIN_7;
/*Configure GPIO pins : PB8 PB9 */
GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
/*Configure GPIO pin : PI4 */
GPIO_InitStruct.Pin = GPIO_PIN_4;
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief Period elapsed callback in non blocking mode
* @note This function is called when TIM6 interrupt took place, inside
* HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
* a global variable "uwTick" used as application time base.
* @param htim : TIM handle
* @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
/* USER CODE BEGIN Callback 0 */
/* USER CODE END Callback 0 */
if (htim->Instance == TIM6) {
HAL_IncTick();
/* USER CODE BEGIN Callback 1 */
/* USER CODE END Callback 1 */
* @retval None
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
/* USER CODE END Error_Handler_Debug */
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
