HI, new to the forum. Please forgive me if this has been covered before. I wanted to make some holding tank heaters for my rv. I had a spool of nichrome laying around from a previous project so that was my heater medium. I made two heaters using fiberglass as the backing fabric and silicon for insulation along with aluminum to reflect heat back towards the tanks. I chose AC as the power source instead of the 12v coach batteries to conserve power and because my rv has a generator if shore power isn't available.
I got it all wired up, two heaters in parallel showing just over 40ohms total resistance so they're pulling roughly 3 amps but my rv seems to have a real problem accepting the heaters. The rv has GFI circuits and they pop every time I plug it in to the rv while it's on shore power from my house. The house GFI also pops. I can plug them into an extension cord directly to a GFI from my house with no problems and getting right around 80 degrees heat but every approach I have tried using the rv on shore power will pop the rv and house GFI.
I can run the heater using the rv generator but using shore power refuses to hold the load. I tried grounding the plug to the rv chassis and that made a small difference by poppiing the GFI after a second or two instead of immediately but this still isn't satisfactory of course.
The circuit is simple with a coil of nichrome wire laid flat on the backing connected through copper wire to the terminals of a standard a/c outlet plug and a separate ground to the rv chassis. Each heater offers roughly 85 ohms of resistance. They are connected in parallel but will also pop the GFI when connected in series but that configuration provides too little heat to be any good to the holding tanks.
Any thoughts?
Any thoughts?
