Rex-c100 and Nichrome
omar2565
Joined Aug 7, 2024
Hi Guys, so i'm building a thermoforming machine for pet plasctic it will heat up to 160 degrees Celsius, for the heating element i will use a nichome
NI90 wire and to control the temperature i will use a REX-C100, SSR-40A Relay and thermocouple type-K
So my question is do i need a seperate power supply to heat up the nichrome or will the REX-C100 do the job like the image i linked bellow.
djsfantasi
Joined Apr 11, 2010
9,237
Gets me a page not found…
omar2565
Joined Aug 7, 2024
The area where the Nichrome wire will be placed measures 229 mm by 317 mm, giving a surface area of 0.072573 m².
I'm planning to arrange the Nichrome wire in a zigzag pattern. The wire is N90/23G with a resistance of 0.09Ω per inch.
Right now, I'm trying to determine the appropriate length of Nichrome wire I’ll need and whether I should power it directly from the main power supply or use a separate one.
