What substance can I use to suspend nichrome wire in custom cartidge heater?
strantor
Joined Oct 3, 2010
6,875
I'm designing a widget and it needs a cartridge heater of unique dimensions and construction. I know you can special order cartridge heaters to your spec but I don't know what my spec is yet, and it might go through several iterations before I arrive at something I would feel comfortable placing an order and waiting for. Until then I would just like to roll my own cartridge heaters. I can't find much information about this. The thing i need mostly to know, is what kind of substance should be used to suspend the heating in wire in, inside the cartridge. If you take the guts out of a commercially made one, they will be suspended in some white chalky stuff, but I don't know what it is.
I think the substance needs these attributes:
-Good thermal conductivity
-Bad electrical conductivity
-little or no shrinkage or expansion at high temperatures
-Does not ignite/burn, melt, or release toxic fumes below 1000C/1800F
-preferably a paste that will harden on its own or upon first heating.
-can withstand many many heat cycles before cracking or otherwise failing.
I have made a couple already using furnace cement (this stuff) and it worked but I think this is a thermal insulator rather than a thermal conductor, so it probably could work a whole lot better if I used something more appropriate. Something like Boron Nitride I think is probably ideal and can be had in a paste, but when I tried to use it, after the paste dried it was much to fragile, almost like the excrement of the "pooping dog" firework or the "magic black snake" firework.
strantor
Joined Oct 3, 2010
6,875
It could also be some kind of wrap/tape, cloth, or string. That might even be better, as then I could fill the gaps with boron nitride. The idea is just to keep the nichrome wire from contacting the metallic interior of the cartridge.
