Ni-MH Battery Pack
abejmart
Joined Apr 16, 2020
11
Hi all,
First time posting on this forum, please don't kill me if question is dumb ;)
I have Ni-MH Battery pack (Eztec 9.6V 600mAH). This pack is about 5 years old, and does not hold any reasonable charge anymore.
Is it possible to replace it with pack of "Amazon basics AA batteries"?
Thank you,
Andrew
38,830
You should be a able to replace them with NiMH types (those you referenced are non-rechargeable alkaline) unless there are more than two wires from the charger to the battery pack, indicating there is some type of monitoring circuit..
In that case, you would need to open the battery case and see if you can substitute the new batteries.
8 NiMh cells will give you 9.2V nominal.
abejmart
Joined Apr 16, 2020
11
In that case, you would need to open the battery case as see if you can substitute the new batteries.
Thank you. Will do
Audioguru again
Joined Oct 21, 2019
6,826
The Amazon alkaline batteries have ZERO spec's so how can you compare them to Name-Brand alkaline batteries that have detailed spec's?
Modern AAA Ni-MH cells are better (800mAh) than your larger (you said AA) and lower spec (you said 600mAh) cells.
The charger might not detect full charge then turn off. It might simply have a timer then a modern battery will never have a full charge.
abejmart
Joined Apr 16, 2020
11
I suppose it charger have timer, nothing will help. Name or NoName... I hope new AA Ni-MH will do the trick.
abejmart
Joined Apr 16, 2020
11
The original batteries are flash-welded with almost no heat. If you solder to batteries then you might (probably) melt the plastic insulation inside.
Thank you! I wouldn't even think about temperature!
I have soldering tool that have regulated temperature. Will this do the trick? What temperature should I use?
Audioguru again
Joined Oct 21, 2019
6,826
High quality batteries might have a corrosion resistant stainless steel case that you cannot solder. Trying will melt plastic insulation inside because soldering is at a temperature too high for plastics.
EDIT: Modern AAA batteries are smaller but are even better than the original AA size cells. Can you fit 8 AAA cells and their holder in?
abejmart
Joined Apr 16, 2020
11
I can't find any 8*AAA batteries holder, unfortunately. Will have to give a try to soldering, and if it will fail, then will try to get AAA holder somewhere...
Thank you
Audioguru again
Joined Oct 21, 2019
6,826
I have had the battery contacts in cheap battery holders like that melt through the plastic because the springs are too weak to make good connections.
abejmart
Joined Apr 16, 2020
11
and this is wrong size... i would need flat one. can get 2 holders 4*AAA, but again not sure if it will fit properly.
I could try to fix connectors to the original box, and then push AA batteries into it.
28,344
The problem with soldering to the batteries is that it melts the plastic seals and then the battery dries out and fails in a fairly short time, just a few weeks..
