I am pretty much a newbie when it comes to component design so I am asking for help in determining if what I want can be done with smaller components.
Below is a basic layout of a circuit I would like to construct.
- I have 4 push buttons in 3 different locations
- Each location needs to be able to be operated independently and not tied together with other locations
- Three 4PST relays in the normally open state are used and powered on individually by a selector switch giving a particular control location operation control.
- Each location will be less than 10 meters from the motors
- The amount of current at each dry contact will be <1mA
While the drawing below only uses 4 dry contacts per location the final design will require 24 dry contacts
What I want to do is not use relays but an IC instead. I want the circuit that powers the switching to be isolated from the switching.
So my newbie question is....
Can an analog IC switch be used in place if the relays?
Is there a recommended product?
Thanks Mike
Thanks Mike
