New to the L200C regulator
Drmario5237
Joined Oct 14, 2018
65
Hello I'm new to integrated circuits. Someone suggested the L200C regulator as a current regulator/ voltage regulator for my project but I don't really understand how it works. What are each of the Pina for on it. How do you hook it up to get it to be either a current regulator or voltage regulator and how do I get a steady 5volts at 2amps from it. Is there anywhere on the net I can learn more about it. Thanks.
Dodgydave
Joined Jun 22, 2012
11,395
Yes it was me...
Here is a circuit that uses the L200c regulator, current limit is set with the resistor between pins 2, 5..
Iout=0.5V/ R-limit
The voltage output is the same as other regulators (V= (1+R2/R1) x 2.75)
http://www.zen22142.zen.co.uk/Circuits/Power/l200.htm
bertus
Joined Apr 5, 2008
23,001
@Dodgydave , The given formulas do not have the correct values.
The current will be : Iout = 0.45 / R-limit
The voltage will be : Vout = 2.77 * (1+R2/R1)
Bertus
