Need to solder a 4x4mm QFN by hand
cmartinez
Joined Jan 17, 2007
8,877
UPDATE:
It worked! ... I baked all the circuits in my small electric oven, carefully timing 4 minutes and gradually raising the temperature "by feel", until I saw the solder paste liquify, then I waited about 20 seconds, and gradually lowered the temperature again.
Nothing was damaged, and the PCB's came out nice, neat, and clean.
Maybe my next step will be adding a thermocouple and a small controller to the oven to automate the process. But I've got more pressing things to do at the moment. I'll be updating this thread when the moment comes.
Ian0
Joined Aug 7, 2020
13,306
In mine, I attached the thermocouple to an old piece of pcb, which I then attached to the rack when the pcbs go.
cmartinez
Joined Jan 17, 2007
8,877
I assume the intention of that arrangement is to directly measure the temperature of a sample PCB as a reference, instead of measuring a random point inside the oven?
Ian0
Joined Aug 7, 2020
13,306
Precisely. I thought about attaching it to the metal rack, but the metal rack would have completely different thermal characteristics to a fibreglass pcb.
My colleague cooks some pcbs in the oven, and we buy in some that are assembled in China. Sometimes I can't tell which is which. (My colleague isn't quite as good as the Pick-and-place at aligning a 64-pin TQFP, and that is generally what gives the game away)
cmartinez
Joined Jan 17, 2007
8,877
Which configuration of thermocouple do you use? Do you use the "naked" type, or encapsulated? How do you attach it to the sample PCB?
Naked:
Encapsulated:
