I have 2 identical Alpine amps, one has a blown (part of it blown off) SMD diode, I can make out UF 42 on it. Odd that the other identical board I was going to use the part off of has several of them by the power mosfets (irfs) but they are all UF 51. I guess they changed up the circuit? I cant find an ID for this SMD online. Any IDEAS what SMD diode UF 42 or UF 51 is and if they would be interchangeable?
I replaced the two shorted Irfs (power mosfets) and fired it up and it blew the 7.5 amp fuse on my PS and blew the two mosfets I just replaced. After using a 30x magnifying glass I found this bad diode by the mosfets and hopeful this is the short blowing the mosfets.
Any help IDing that SMD would be much appreciated.
