Need to find the current in this circuit!
Withering
Joined Mar 25, 2018
8
I've attached the circuit problem as a picture.
I worked out the ideal voltage to be 50 V.
The resistance should be 8 ohms.
Having trouble finding the current when the voltage is 22 V.
Is Ohm's law sufficient to find this current?
Moderators note : shown image full size
bertus
Joined Apr 5, 2008
23,001
You are right about the voltage of 50 Volts and the resistor being 8 Ohms.
When the Vi = 22 volts, the current will be coming out of the device.
The value will be negative.
Can you calculate the current now?
Bertus
Withering
Joined Mar 25, 2018
8
I honestly don't know. I know I am close; but, I've never seen questions like this in the past and I'm lacking intuition for these questions that I know will end up being easy to me (not easy at the moment).
danadak
Joined Mar 10, 2018
4,057
Table looks linear (plot it on graph paper), so
I = aX + b equation of straight line
first table entry
0 = a x 50 + b or b = -( a x 50 )
second table entry
2 = a x 66 + b = a x 66 - a x 50 = 16 x a or a = 1/8
Therefore b = -(a x 50) = - 50 / 8 = -6.25
Therefore
I = V/8 - 6.25 general equation
For 22 V
I = 22/8 - 6.25 = 2.75 - 6.25 = - 3.5
Check last entry
10 = 130/8 - 6.25 = 10
Regards, Dana.
Ramussons
Joined May 3, 2013
1,572
Bertus
I'd say it's a 50 Volt Zener with a 8 Ohm resistor. so the current would be 0 at Vi = 22 volts.
bertus
Joined Apr 5, 2008
23,001
@Ramussons , That is also an other possibility, but in the question there is an ideal voltage source is asked for.
Bertus.
PS I have shown the image full size in the openings post
