need to display multi shapes on 7 segments without controller?!
ahmedzaidan
Joined Jul 22, 2017
39
Hi All,
I am trying to display the following shapes on one 7 segments display depending on three control signal .if one of them high i want to display the first shape if the second one high i want to display the second shape and so on ^^
can i do that without using any controller ?!
Thanks in Advanced :)
ian field
Joined Oct 27, 2012
6,536
Hi All,
Probably easier in the long run to use a OTP ROM, but they're getting hard to find. The capacity will be more than you need, so you could just go for the full ASCII CHR set. There used to be off the shelf ROM chips, but I haven't seen one for decades.
Some TV sets shifted the bit pattern for all the digits at once into a SIPO shift register.
ahmedzaidan
Joined Jul 22, 2017
39
All you need is a bunch of diodes and resistors. See this https://i.stack.imgur.com/XRe0Q.png, but I would use a separate resistor in series with each diode, instead of bunching them up together.
thank you :)
and what the value of each resisor ?
thank you for your appreciated effort :)
ian field
Joined Oct 27, 2012
6,536
If you like doing things the hard way on a large PCB area. Its basically building you own hand wired ROM.
Very small OTP ROM chips were very common at one time. There's still some of availability of EPROM chips and a fair choice of EEPROMS.
The redundant capacity is a small price to pay to get out of hand wiring a board full of diodes.
WBahn
Joined Mar 31, 2012
33,086
Hi All,
Just three patterns -- and THOSE three patterns?
What if more than one of your three control signals is HI? Or what if none of them are HI? Or is your system such that you are willing to assume that exactly one of your control signals is HI at all times?
kubeek
Joined Sep 20, 2005
5,796
OP said he needed only those three symbols, so a few diode seemed simpler than learning how to program an eeprom.
LesJones
Joined Jan 8, 2017
4,526
The E and F segments are allways on so they just need connecting to the supply via resistors. For the "0" display you need four diodes feeding segments A, B, C, D from the control signal. For the "L" display you need one diode from the control signal to the D segment. For the "H" display you need three diodes feeding the B, C, G segments from the control signal. You will need a current limiting resistor on each segment. For someone to draw the schematic you need to specify if the display is common anode or common cathode, The supply voltage and the required segment current.
Les.
ian field
Joined Oct 27, 2012
6,536
Just those symbols are OK with diodes, but adding more later can get out of hand fast.
AFAIK: a flash EEPROM only needs a few logic gates to sequence the select pins in the right order. There's no weird & wonderful Vpp levels to deal with. 0.3" footprint EEPROMS were fairly common on PC motherboards not all that long ago. It might even turn out that the EEPROM chip turns out cheaper than the bag of diodes, and could easily take less board space.
ScottWang
Joined Aug 23, 2012
7,505
I also thought about to use EEPROM and I did something like that before, but it was more and more complicated, if the TS no any acknowledge about that or no any EEPROM writer then that is the problem or the schedule will be delay.
Wendy
Joined Mar 24, 2008
23,807
Diode logic comes to mind If you need more help w/ this tread PM me?
BTW are the dispays common anode or common cathode?
absf
Joined Dec 29, 2010
1,968
At first, I tried with 4049 inverting buffers but I was surprised that the voltage at the o/p of the buffers was >2V and I have to reduce the current limiting resistors to 100Ω. So I immediately think of using ULN2003 (max 500mA), though a TTL LS should work too sinking about the same amount of current.
Allen
[edit] I checked with 74LS17 datasheet. It has the advantage of the schmmitt trigger inputs and can prevent contact debounce. But its I(OL) is only 8 mA (per gate?), so not sure if it can drive 6 segments in "0"
ScottWang
Joined Aug 23, 2012
7,505
Allen
When you using the cmos and still want to get the higher current then you can choose as the inverter 74HC4049 or the buffer 74HC4050.
ScottWang
Joined Aug 23, 2012
7,505
SN74LS17 from TI and it provides the max current is 40 mA, please check the bottom of the page 2, digikey still has the SN74LS07DR sale online, so this kind of product still has its market.
