Need to build a circuit + Power supply check plan for me
Endless Paradox
Joined Mar 16, 2018
7
Like the title says i need to build this circuit on a stripboard with a power supply:
The power supply circuit isnt included but it is connected to this circuit.You dont need to matter about the pieces part just watch if the connection links or breaking of copper tracks which are the rounds makes something bad in the next picture.
Here is the plan including the power supply on top and the circuit on the paper down.I know it isnt very easy to understand i need to redo it after :D
Please check if it is good i dont wanna burn my pieces XD.
Endless Paradox
Joined Mar 16, 2018
7
The circuit looks ok, can't tell about the veroboard layout,.. . I would use a better chip than a lm741..
I tried assembling it but it doesnt work it is for a project so i cant change the chips :/ forced to use lm741
Do you think you can check if i have any connection error?
DickCappels
Joined Aug 21, 2008
10,662
Suggertion: keep the area on the board around the "domestic supply" (AC Line) free of copper 8 mm on all sides and 8 mm between line and neutral to prevent problems with arcing and leakage current. Clean flux off of this area using alcohol.
