I need a circuit that can give a 12V 2 Amp DC output from 8 to 13 Volt DC
Thanks in advance.
Thanks in advance.
DC to DC Converter. Companies like Cosel USA make them as well as others. Here is an example of a 30 Watt unit which at 12 VDC would be 2.5 Amps.Hi,
Thanks in advance.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G21500Hi,
Thanks in advance.
Unfortunately once you go below ~10 - 10.5 volts over 95% of the batteries charge has already been used up and going any further will start to do damage to the battery unless its a purpose built high discharge cycle rated deep cycle battery.I'm in Syria and we use SLA to lighting a LED when the power outages
but the power is off about 18 hour per day so the battery is go below the 10 V and the LED need a 12 V to be lighting good
| Thread starter | Similar threads | Forum | Replies | Date |
| N | Need help with choosing proper step down voltage regulator | Power Electronics | 14 | |
Need a simple circuit for dc low voltage regulator | General Electronics Chat | 6 | |
Need the answers about regulator | Power Electronics | 10 | |
| P | Need an external regulator | Power Electronics | 1 | |
| A | Need help with 2V regulator circuit | Power Electronics | 4 |
