Need SOLDERING (non PCB) Projects Using This 6-pin HKE Relay, Preferably an Automatic Light With an Ldr.
Pinto_Marcelo
Joined Jul 19, 2023
5
Hello world, I'm new here, and I tried to search for some projects with this Relay but I couldn't find it.
I would love to solder circuits WITHOUT PCB, like this: https://www.youtube.com/shorts/Rm68zeCjxLg
preferably an automatic light with an ldr.
I've been studying this datasheet, but it doesn't work like other relays...
Thank you!
As you can see, this 6-pin relay has no diagram.
And these pins I soldered trying to do a test.
Pinto_Marcelo
Joined Jul 19, 2023
5
That relay will need additional components depending on how sophisticated the circuit needs to be.
Yes, I want to use this relay with an ldr... probably i'll need transistors/mosfets...
if you know some project with this relay specifically, post here!
thx!
dl324
Joined Mar 30, 2015
18,490
Tell us about the light you plan to switch. If it's line powered, I wouldn't advise making some free-form circuit to control it.
With an LDR, you should add circuitry to give you a well-defined indication of light level and have some hysteresis to prevent the light from rapidly switching on and off at the ambient light level you want it to turn on at.
