Need schematic Philips BT100 bluetooth speaker
mrel
Joined Jan 20, 2009
189
Hello
Any one know where can get Schematic for Philips BT100 bluetooth speaker.
The charger port use micro usb port ,the micro usb port got pull of the pc board.
Need know where the positive and negative wire on the pc board to charge the the battery.
mrel
mrel
Joined Jan 20, 2009
189
If it's a micro USB port, charging is usually done through pin 1 (VCC) and 5 (GND).
The company glue usb port to the pc board went the usb port got pull off the pc board it pull the copper trace off the pc board,now no copper trace on the pc board.
Don't know which trace is positive and negative trace.
mrel
Joined Jan 20, 2009
189
