I'm looking for a schematic for a life Fitness treadmill 95T. The controller in question is a a080-92381-0000. Due to moisture, the incline level switch shorted a component on the controller. It burnt an smd ferrite bead, or I believe it's a ferrite bead. I replaced it with another smd ferrite bead, and also got a new switch. The incline switch does nothing. When connected. The treadmill starts up, but when it calibrates the incline to 0 degrees ( going down). It does nothing. Pressing the button manually does nothing. The treadmill works fine without the incline. When you unplug the connector wire that goes to the switch and start the treadmill. It goes up .this tells me that the motor is fine and something is telling the motor to go up or down. It just can't tell me when the 0 degree angle is(Home). Anyone in this forum happen to have a schematic to this board or have worked on one of these?
The picture shows the component that was blown(right of my finger, right next to the connector.
Any help with this would be appreciated!
