Need pseudo code to check ACK or NAK and to generate ACK or NAK i2c communication
anukalp
Joined Jul 28, 2018
158
I am looking pseudo code to check ACK or NAK and generate ACK or NAK in i2c communication
as given in diagram The master issues Start, then sends the slave address and slave sends a single ACK or NAKa after receiving 8 bits
Code:
void main (void)
    //How to write a pseudo code to check ACK or NAK and to  generate ACK or NAK
BobaMosfet
Joined Jul 1, 2009
2,211
Well, take a close look at what the SCL and SDA voltage levels are in the drawing you provide. That will give you a pretty good idea of when to raise or lower the value of a signal pin if you're trying to do i2c all by yourself.
