Need of circuit for sense voltage
Dzoro
Joined Feb 1, 2019
194
I need a circuit that when senses a pulse of voltage from 1-5 v dc doesn't matter how much to give continuous output and when senses another pulse to turn off.
Is that possible to do with some simple circuit
danadak
Joined Mar 10, 2018
4,057
1) What is the pulse width and repetition rate ?
2) Resolution you want in the measurement ?
3) Absolute accuracy of measurement ?
4) What do you do withe the measurement data ?
5) Turn key out of the box solution or design from scratch ?
Regards, Dana.
28,461
YES, definitely possible. In fact, that function is part of a product that I designed several years ago. Easy to build, does not need calibration , and it does not draw much power. Also, not expensive to build.
It will switch on with the first pulse, off with the second pulse, on with the third, and alternating as long as the pulses keep arriving. If you want any other action it gets more complicated.
Danko
Joined Nov 22, 2017
2,241
Like this?
EDIT:
Name of CD4013 pin , connected with collector of Q1 is CLOCK.
Not used inputs of U1 should be tied to GROUND.
Dzoro
Joined Feb 1, 2019
194
Yes buti don't have 4013 can i use 4747
Can you sent a circuit
djsfantasi
Joined Apr 11, 2010
9,237
You should be able to use the 7474. I’d tie the Preset and Clear to ground since they are not being used. You don’t want to leave them floating.
djsfantasi
Joined Apr 11, 2010
9,237
Hi djsfantasi,
Preset and clear should be tied high as they are active low signals on a 7474 (On a 4013 they are active high.)
Les.
Thanks, Les! The futurelec page wasn’t clear to me on that point. I checked another datasheet.
The pinout diagrams didn’t indicate these pins were active low. I would have expected bar-CLR or bubble-CLR
Dzoro
Joined Feb 1, 2019
194
On danko's circuit what is the name of the input pin that goes from tho colector of the seconf transistor
28,461
My design was intended to detect and trigger on much smaller pulses, so it used 2 stages of op-amp, each stage had a gain of 1000. So yes, the two transistor amplifier should be adequate. Mine used capacitor coupling so ambient DC or DC drift did not cause problems.On the CD 4013 all unused logic inputs should be tied low, on the 7474 clear and preset are active low. I never used TTL very much, CMOS is much easier, and much lower power.
Was the continuing alternat action acceptable?? Or did the TS just want on once then off?That gets a bit more complex.
28,461
For power on reset with a CD4013 dual FF, use a 10K ohm resistor to negative supply, from the reset pin, and a 0.01mFd capacitor from the supply positive to that reset pin. You might need to experiment with values, it depends on supply voltage rise time at turn on.
djsfantasi
Joined Apr 11, 2010
9,237
The TS has already stated that he cannot use a 4013, as he doesn’t have access to one. He did have a 7474. Danko provided a circuit that used a 4013 as a T flip flop. It could be implemented with the 7474 which he had.
38,885
So the power-on reset for a 7474 would be just opposite a 4013, with a 10kΩ resistor from the Reset input to the positive supply, and a capacitor to ground.
I would use at least a 1μF cap, if not larger, to insure a good reset for a possible slow power supply start-up.
