Need ideas for a cheap but effective locating system
dl324
Joined Mar 30, 2015
18,393
yeah but I only need to cut 1/4" deep. My trusty dewalt circular saw should manage.
Depending on how much cutting you need to do, you may want to use a cheap saw. That's what my neighbor who's a concrete contractor recommended. He said the dust would trash the saw...
38,552
If you keep a stream of water directed at the cut, the dust should be negligible (which you likely want to do anyway to cool the blade).
MikeML
5,444
When I installed one, I had to cross two concrete driveways. I used my Skill saw with a carbide tipped blade, set the depth to about 1/2", and cut a groove in the fiberous material that makes up the expansion joint. I just pushed the wire into the resulting groove, and then use a little RTV as an adhesive to hold it there. Worked like a charm. This was in snow country; never snagged it with the snow shovel, which is what I was worried about...
