Need help with with darlington pair setup to power 555 timer circuit
robnoper
Joined Mar 5, 2019
24
OK, so you may still need a Darlington. Leave the 2N2222 as it is but disconnect the 10k from the base and connect it to the base of the extra NPN transistor. Connect the emitter of the extra transistor to the base of the 2N2222 and connect the two collectors together.
It is possible that the 2N2222 may get warm in this circuit. If it does then there is a modification that will keep it cooler.
Sorry to be a pain, but could you sketch this part out..nothing fancy just enough so I can understand and modify my schematic. Im trying to learn more as I go but slow. appreciate your patience with my lack of knowleage.
AlbertHall
Joined Jun 4, 2014
12,663
Oooppsss!
It occurs to me that with that 1.5V input signal there is barely enough voltage to turn on a Darlington. An alternative solution is required - probably an NPN and a PNP.
Bernard
Joined Aug 7, 2008
5,784
A sketch of the grounding circuit. The output load is simulated by 40 ohm R, RL. Input .8 to 1.5 V. About a 10 deg. F temp. rise on 2N2222
Bernard
Joined Aug 7, 2008
5,784
My personal pref. is a TIP127, PNP darlington, 100V, 5A, B 1000, emitter to +12V, collector to load, & 3.3k between base & Q1 collector.
Input from .7V to 1.5 V. derived from 50k pot.
robnoper
Joined Mar 5, 2019
24
driver, 35 deg. F rise on RL.View attachment 173551
Tried this at the weekend and worked perfectly....prototype now up and running on Veroboard. Thanks for your help.
