need help with some leds
stuntpiloot
Joined Nov 26, 2024
Hi, I'm making a game (simple) where one led needs to be on until you break connection with led one then led two needs to light up. All with max 9v. Any ideas how?
meth
Joined May 21, 2016
314
SPDT relay?
Edit: for more meaningful answer you need to provide details on how much LED's in total, max size of enclosure and so on.
jiggermole
Joined Jul 29, 2016
188
If its just a 20ma led you could probably get by with a pushbuton and a resistor. if the pushbutton has a normally open and a normally closed you only need the one. meth's suggestion for relay would also function in exactly the same way I described.
meth
Joined May 21, 2016
314
True, the "break connection" moment isnt explained, is it by pushing a button or through electric signal which is actuated using some other method than pushbutton...
