need help with smps for a welding machine w/ universal voltage input.....
knonuthin
Joined Apr 28, 2016
ok i have an issue with my welder. It can run on 110 or 220. I almost always have it hooked to 220. Now whenever i turn it on when plugged into 220 it throws the breaker as if it were a dead short. If i plug it in to 110 there is a bank of relays i can hear them switching the lights come on but nothing else....? I'm guessing it is something with the power supply i should mention this is an inverter welding machine basically a big high current chopper...
ian field
Joined Oct 27, 2012
6,539
How are you getting 110V? - the SMPSU will probably throw a wobbler if fed from an excessive impedance supply.
You're probably lucky it didn't go bang on 220V. Early universal voltage units created a voltage doubling rectifier by using 2 reservoir caps in series and shorting the tap to one of the AC arms of the bridge rectifier. Early on it was a user set jumper link, this was superseded by a triac to make the connection. It started with a discrete component voltage detector, but fully integrated units arrived eventually.
A fully integrated type might be available as an off the shelf part. I'd have to see the discrete component type and make a decision, repair it or decide what voltage to use and hard wire it or not hard wire it.
knonuthin
Joined Apr 28, 2016
from what i can tell and bear in mind this is just based on looking at the traces on the board (not to mention im a metal worker not a technician) there are 2 or 4 sets of optocouplers and two m osfets. there is also an 8 pin smd ic on the back which i was thinking may be an op amp but i cannot read what was written on it. as for the discrete componants there is a bank of ...resistors..????... marked ntc 470.... i dont know if any of that helps but either way i appreciate your attention and input...
knonuthin
Joined Apr 28, 2016
its a simadre 5200 3-in -1 welder and plasma cutter. i tried to find a schematic and tried emailing the company with no luck.
ian field
Joined Oct 27, 2012
6,539
There was a DIL-8 voltage sensor that directly drives the triac - I have no idea whether it was produced in SOIC-8 footprint.
Could be anything - a lot of switcher control chips are 8 pin.
The number off it might help.
knonuthin
Joined Apr 28, 2016
i am having a hell of a time trying to make out what was written on that surface mount ic, i was however able to read the writing on a 3 pin to-220 component ....FQP 5N50C .... Is it possible this is my problem...?
ian field
Joined Oct 27, 2012
6,539
Not possible to tell till you pick up the DMM and start checking stuff.
