Hi guys,
My project is A portable energy efficient rechargeable LED lamp.I have been working on my project for quiet some time and i haven't had any luck getting it to work as intended. I would really appreciate it if you could help me with my design since i am not an experienced in circuit design.
Let me give you specification for the part of my project.
- I have to use DC-DC converter circuit in boost configuration to boost from 6V battery (12AH) to 15V as a source to drive the LEDs.
- I have to use PWM (ranging 10%-90% duty cycle) to control illumination of the 2 LEDs (each 12V 10W at 800 lumens)
If you check my circuit i use PIC16F627A microcontroller to generate the PWM. I use LT1170 IC for DC-DC converter circuit to boost to 12V (i can boost it to 15V but i used the circuit from the datasheet of the LT1170 IC). I used mosfet IRF540 to drive the LEDs. I am using the LEDs in parallel because i want 600 lumens of light from the LEDs at 50% duty cycle. One 12V 10W LED provides 800 lumens max and i want 1200 lumens at 100% duty cycle and also taking into considerations of voltage of 12V when i used LEDs in parallel thats why i am using 2 LEDs in parallel.
When i tested my circuit i get current through the load to be 200mA. Now i know that i have to use constant current source to drive the LEDs but i dont how to design the constant current source. I have to provide atleast 1.2A current to my LEDs for it to work at 1200 lumens brightness @ 1.2A. I am not getting that current. Can anyone give suggestions on how can i get the current of 1.2A from the LT1170 IC?
Note: Keeping in mind that i am using 6V 12AH rechargeable battery as source for the DC-Dc converter and the PICMicontroller. The two switches that i have connected to the PIC are used for varying PWM duty cycle.
