Need Help with My BCD Counter Design
Yaaw
Joined Oct 17, 2023
So I based on the Title I need help with my counter, I want to stop the counter from counting after it reaches 0 on the 7 segment display, So even if I pushed the CLK (pin15) when at 0, it wont go back to 9. This is my Circuit Design so far.
Yaaw
Joined Oct 17, 2023
I'll give you a clue:
use CLOCK INHIBIT input
I know that cutting the connection of Clock Inhibit to GND would stop the count, but In my knowledge it has to be a form of a switch. I just want to automatically cut the connection, just like a countdown timer. Are there any other way to this?.
35,233
Logic gates are called "gates" for a reason.
Study how a 2-INPUT AND gate works.
Then study De Morgan's equivalent gates.
Yaaw
Joined Oct 17, 2023
Ohhh, I see, I just have to input the CI with High Input, and this comes from inverting the binary 0000 = 0 (now 1) and then adding them up using and gates.
dl324
Joined Mar 30, 2015
18,478
You have a switch that allows you to switch between up and down counting. It would be helpful if you stated which direction it's counting.
EDIT: corrected grammar - missing apostrophe.
I dont really now much about this, So How would I achieve this?
You don't have to worry about switch bounce in a simulator.
What makes you say that? It would be more typical to use gates/flip flops to implement your stop feature.
38,863
This is another example of how simulators can lead you astray.
So can a circuit breadboard, if you don't take the real characteristics/tolerances of the devices into account, when you translate it into a PCB circuit.
A simulator is like any other tool (and it's a very good tool).
If you don't know its limitations, you will likely get bit in the posterior. :rolleyes:
The limitations don't mean it's a bad tool.
Audioguru again
Joined Oct 21, 2019
6,826
Mixing logic types does not work.
A CD4510 is Cmos and has a very low output-low current.
An SN7404 is very old TTL and has a very high input-low current.
dl324
Joined Mar 30, 2015
18,478
When is your assignment due? Are there any constraints on how you're supposed to implement the stop feature?
