Need help with an electro-pneumatic circuit
NikolaJP
Joined Nov 6, 2018
22
I need to have 2 pistons, and one pistons works if I put 1 metal ball in the machine, the other piston works if I put 2 balls into the machine.
The detection of the number of balls is done in the electrical part and the piston is pneumatics.
Also, I think I can't use a button since there is only one slot and it won't detect the number of balls.
The pneumatics scheme is easy since it will be controlled usind solenoids, but I have no clue about the electrical part.
Thought about using a sensor, but have no idea how to use one without a microcontroller.
pmd34
Joined Feb 22, 2014
529
Hi NikolaJP, can you explain a little be more about "putting [your] balls into the machine"!!
The simplest method would be to use a "proximity sensor" which can detect proximity to metal objects, these could activate your pneumatic solenoid valves directly, you can also get optical ones such as "beam break" detectors which may also be suitable but we need a clearer idea of how your machine works to be able to suggest how you might distinguish between one and two balls.
NikolaJP
Joined Nov 6, 2018
22
Thanks for the answer,
I was also thinking about using a proximity or metal detecting sensor, but I don't know how to add and use them in a circuit without a microcontroller, I don't even know their symbols.
What i wanted to do is to put a sensor and then if it detects that one metal ball has been inserted, it activates piston 1, and if it detects that 2 metal balls have been inserted, it activates piston 2.
pmd34
Joined Feb 22, 2014
529
This explains a little the wiring for the 2 main "flavors" of proximity detector:
https://www3.panasonic.biz/ac/e/fasys/sensor/proximity/gx-8/circuit/index.jsp
You could manage without a microctontroller, but you would need to use a couple of timing relays.
Something like this:
https://www.aliexpress.com/item/AC-...lgo_pvid=f4e0eb9b-61d3-45aa-a644-062a086ac074
So.. Ball one goes in- activates the first timing relay, (which now connects / allows the same sensor to activate timing relay 2). If ball 2 goes in before the time runs out, this will activate relay 2 and the second pneumatic piston.) If 1 finishes its delay and relay 2 is not active, then it switches pneumatic piston 1.
NikolaJP
Joined Nov 6, 2018
22
Thanks, is there a simpler solution, or can you give me an example? I have to finish it today.
NikolaJP
Joined Nov 6, 2018
22
I am also thinking about using the weight of the balls, since 2 are obviously heavier than 1, but Idk if there is any element or button that can do that
pmd34
Joined Feb 22, 2014
529
You would need to explain a bit about where the balls are in the machine for me to get an idea of how to detect them. If they are on top of each other then you can just use 2 sensors.
djsfantasi
Joined Apr 11, 2010
9,237
What do you mean by this statement?
Depending on the chute where the balls are inserted, why couldn’t you use a microswitch to detect the balls?
The switch contacts could be used to provide the logic (along with a timer relay) using the technique @pmd34 outlined in his post.
If you think this will work, I can provide more detail.
NikolaJP
Joined Nov 6, 2018
22
It should work like a vending machine, where you insert metal balls instead of coins ( but it doesn't really matter since it is just in the explanation of the problem, I think it would work the same if I dropped coins or any other metal objects of standard size and weight). If You drop 1 ball into the slot, the first piston activates, if you drop 2 balls (or coins) then the second piston activates, but the first one doesn't.
@djsfantasi your idea sounds good, If there isn't a less complicated way to do this, like using the weight of the balls or the fact that they are made out of metal, then I would love to use this method, if you can explain it to me.
djsfantasi
Joined Apr 11, 2010
9,237
Sometime today is likely. Due to the snow storm here, they postponed the Drama Festival. I’m visiting my grandson in a couple of hours, but will take a look when I get home
NikolaJP
Joined Nov 6, 2018
22
Ok. I need the circuit for monday so today or tomorrow is fine. It is 19h now where I live.
NikolaJP
Joined Nov 6, 2018
22
Sorry for the delay. I was prepping a theatrical production for competition this week.
Np, I am asking for help, so I can wait a bit. Just hope you can find time today or tomorrow to help me with this. I need to make the simplest posible circuit for this.
djsfantasi
Joined Apr 11, 2010
9,237
Can you build a 555 timer circuit!
How long between the two balls is acceptable? And how long does it take for your pneumatic cylinders to operate?
NikolaJP
Joined Nov 6, 2018
22
None of that is mentioned in the problem. The closest thing I can imagine is a vending machine. Also, the teacher said we should think how to use the weight of the balls to count them.
djsfantasi
Joined Apr 11, 2010
9,237
Unfortunately, the circuit I had proposed proved to be anything but simple.
The original idea used the contacts of two microswitches, to route power to the correct piston. But then the timing requirement mucks things up.
If you use the timer relays proposed earlier, it would be simplified, but require two of them. The aliexpress link is affordable, but delivery time may be weeks. DigiKey has them - at about $50 apiece, and you need two.
Or I was toying with 555 timing circuits. There is a good tutorial here. Note that in addition to two such circuits with different time periods, you’ll need the “voltage differentiator” circuit shown in the tutorial. The tutorial shows you how to calculate the resistor and capacitors for any time you desire.
Hardly simple.
Others have proposed a microprocessor solution. I developed a solution that requires an ATTiny85, two microswitches, two MOSFETS, two 10K resistors and a programmer. I’ve attached the code below. Note, the programmer link includes excellent tutorials for using it.
I can also supply my semi-schematic/block diagram if you’d like for your reference?
C:
#define Empty HIGH
// time in ms to wait for second ball
const int WaitForBall2=1000
// time in ms for piston activation
const int WaitForPiston=500
// pin definitions
const int Ball1=0;
const int Ball2=1;
const int Piston1=2;
const int Piston2=3;
void setup() {
void loop() {
boolean Ball2Present;
while(digitalRead(Ball1) == Empty) ;
delay_microsecond(Wa1tForBall2);
Ball2Present = digitalRead(Ball2);
If (Ball2Present) {
digitalWrite(Piston2,HIGH);
else {
digitalWrite(Piston1,HIGH);
delay_microsecondWa1tForPiston);
digitalWrite(Piston1,LOW);
digitalWrite(Piston2,LOW);
// the code automatically repeats, for the next cycle
