Hello everybody.
I am in a difficult situation. I have a NIOS 2 project I need to finish, but I do not have the time to finish it. I am looking for someone who could either do it for me, or help me do this.. I can offer you £100 if you do this for me. The deadline is 15th May.
I attached a small pdf with what needs be done. It's simple but I don't know the NIOS II environment enough to do this. I will give you more info if you can help me. It uses the NIOS II tutorial and I have already done that bit. What I need to do is add the SRAM/SDRAM modules to use in the DE2 board...
Thank you
Thank you
