Can i use or gate for switching instead of relay? Because relay consumes more battery power than gate?.
Here i used 1 Input of XOR gate (high or low signal) given from microcontroller 2nd input pin kept dummy.If microcontroller output high ,XOR gate output also high.then can i use this voltage to drive another circuit(5volt ) insted of using relay?.Beccause relay consumes more power from battery.So we can avoide fast discharging of battery?.Please help me.
Thanking you,
Regards
Shrikanth KP
Thanking you,
Regards
Shrikanth KP
