Hello all,
My name is Ivo and I need help with a little project I am currently working on. I tried searching the forum, but didn't find anything similar so here it is. It's a project that requires precise distance measurement (via ultrasound and/or infrared lidar) and the transmission of measurement data wirelessly to a LED display. I don't have much experience with the design and construction of devices at this level, so I am looking for as much of a plug-and-play solution as possible.
Basically, I am trying to get the data from a sensor like TF Mini LIdar or C-SR04 Ultrasound Distance Sensor, send it over something like E32-433T30D Lora Long Range UART SX1278 433mhz or a bluetooth transceiver pair and display it on a simple 3/4 digit LED display. I would ideally like to achieve this with as little additional hardware or coding as possible.
Any ideas and suggestions are welcome
Thank you in advance!
