need help to prove this equation in transistor
32,949
The supposed answer makes no sense.
You have a three terminal device and thus know that Ie1 = It + Ib2 (where Ib2 is the base current into Tr2). Therefore we know that the emitter current must be equal to or greater than It.
Now consider that alpha is something a little less than one and, in an ideal transistor, it is exactly equal to one. If the transistors are ideal, the there is no base current and Iee = It. But your target answer would claim that It = 2Ie.
EDIT: I jumped the gun and when mentally looking at the target answer assumed the middle term went to zero in the extreme of alpha going to unity. Clearly that is not the case. The target answer is correct.
saif-aljanahi
Joined Feb 26, 2016
18
i have solved this question by myself about two days ago and i love to share it here for help any one .
i will call alpha symbol as " a "
IT= IC1+IC2
IC= aIE
IT= a1 IE1 + a2 IE2
IE2= IB1
:. IE1= IC1+IB1
IB1= IE1-IC1
IB1= IE1- a1 IE1
IT=a1 IE1+a2 IE2
IT=a1 IE1 + a2 (IE1 - a1 IE1)
IT=a1 IE1 + a2 IE1 - a2 . a1 IE1
IT= (a1-a2.a1+a2) IE1
32,949
Good job.
A slightly more streamlined approach might be the following:
It = Ic1 + Ic2
It = α1·Ie1 + α2·Ie2 (since Ic ≡ α·Ie)
It = α1·Ie1 + α2·Ib1 (since Ib1 = Ie2)
It = α1·Ie1 + α2·(Ie1 - Ic1) (since Ie = Ic + Ib)
It = α1·Ie1 + α2·Ie1 - α2·Ic1
It = α1·Ie1 + α2·Ie1 - α2·(α1·Ie1)
∴ It = (α1 - α1·α2 + α2)·Ie1
saif-aljanahi
Joined Feb 26, 2016
18
can anyone help my , Derivation of RMS voltage and current , i found it on google but it Difficult
and i have an exam tomorrow
32,949
Simply start with the definition of what you are trying to find.
You have a waveform v(t). If that v(t) is applied to a resistor, it will result in power being dissipated in the resistor. What is that power on average? What DC voltage, Veff, would need to be applied to that same resistor in order to dissipate that same average power?
That's all there is to it. Find Veff in terms of v(t) and you have the derivation of Vrms.
32,949
ok, give me an example, and i will save the equation in my mind, not apply it
Then you are just digging yourself a hole because you want to just memorize things instead of understanding concepts so that you can apply them. Engineering is about problem solving and to be any good at solving engineering problems you have to be able to apply engineering concepts to problems that you have never seen before (indeed, perhaps that no one has ever seen before). The reason why the definition you found on line is confusing to you is that you previously took the short cut and just memorized a bunch of things to pass a test without bothering to understand them well enough to apply them. As a result, you don't understand the prerequisite concepts involved in the derivation. So now you want to double down and just memorize something else. That process will not end well.
So take it one step at a time.
If you have a voltage v(t), what is the instantaneous power, p(t), that is dissipated in a resistance R?
saif-aljanahi
Joined Feb 26, 2016
18
Well I'm agree words , but how to understand thing I can not understand
, in Iraq , Education is very primitive, so do not teach everything but overlook some steps
ok how i will found v(t)
32,949
v(t) is any arbitrary voltage waveform. It can be anything. Today it might be
v(t) = 325 V · sin(2pi · 50 Hz · t)
and tomorrow it might be
v(t) = 14 V + 20 V · sin(2pi · 188 MHz · t + 37.2°)
For your purposes here it is just v(t). The goal is to derive a formula that you can use to calculate the RMS voltage associated with any voltage waveform you might ever be interested in.
22,084
There are two thing which may hep you:
  1. v(t) = i(t)*R, or the instantaneous voltage v(t) is equal to the instantaneous current i(t) times the CONSTANT resistance R. This is also known as Ohm's Law.
  2. The instantaneous power P(t) in a circuit is v(t)*i(t)
This is all you need to know. You may not be professional in math, very few people are, but you should know arithmetic and algebra.
