Need help to identify this resistor!
sudha001
Joined Jan 8, 2016
9
Not sure whether this is a normal resistor or a fusible resistor, also unable to find out the value from the color code.
It has a five bar color code and I guess it is as follows
Grey - Red - Gold - Gold - Black
IMG_20161202_231550.jpg Any help in identifying the component and its value based on the picture provided will be appreciated.
bertus
Joined Apr 5, 2008
22,940
@wayneh The inductors I know have a silver band as the first band.
A 5 band resistor with a black band as the last one is odd.
See the attached PDF for the color code.
Check the bottom of the page of the PDF.
Bertus
sudha001
Joined Jan 8, 2016
9
@ wayneh /@bertus: Thanks for responding to my post. Whether inductor or resistor the color code doesn't fit when calculated from either ends, i.e., either you start from grey/silver or black. The culprit is the two gold lines in the middle. Hope someone throws some light. The component is from a 12V smps. It was positioned immediately after input power and the the X2 suppression capacitor that is why I thought it could be a fusible resistor.
wayneh
Joined Sep 9, 2010
18,123
Ignoring the black, it's an 8.2Ω, 5% resistor.
I believe a 0.82µH could be marked this way (non-military spec, so no leading silver band). Two gold bands could indicate divide 82 by 10 twice. Normally though you'd use a single silver band for 0.01X. Black band shows ±20% tolerance. see
It's possible the black band may indicate something else, like inductor polarity or maybe an overheat indicator, whether this is an inductor or a resistor.
Can you post a photo of the board? Any indication on the PCB?
sudha001
Joined Jan 8, 2016
9
sudha001
Joined Jan 8, 2016
9
@wayneh: I just checked the PCB, it is clearly marked as 8.2 ohm, 2 watt, so problem solved. The black line is the culprit which mislead in its identification. Thanks for your help.
