http://www.youtube.com/watch?v=xeL-8xXQkV8
thank for responding, a counterweight on a shaft work? im not sure what that will do. reciprocating force i am all new to this so still learning, but what would control the shaft? a motor? the motion is like putting a full 5 gallon buck in the back of a truck by the tail gate, than stopping instantly the momentum will cause the bucket to slam in to the cab of the truck. the idea is to launch something? or even the old trick by trying to pull the table cloth out from underneath the dishes without even moving them. just a on/off swich and same speed cycle till turned off.no need for programming then
Why AC motor? any motor that is programmable usually means a servo of some kind, or at least a stepper, if this is point to point positioning, would pneumatics do it or air over oil system?l what im trying to do is make a mechanism of some sort with a small AC motor, but do not know the first thing about any of this. so basically the AC motor needs to be programmable and able to move no more than 5bls but it needs to go forward and reverse in a fast motion kinda like a shake.
Very hard to give qualified opinions with no details.i wish i could give a lot more info on this, i just dont know anything about this stuff. thank you for help me tho.
