I need help on below php program. as I know this program is use for serial communication. I want to know exactly what is real use of this program. does it configure physical port of PC? if not than What program does ?
Code:
<?php
include 'PhpSerial.php';
// Let's start the class
$serial = new PhpSerial;
// First we must specify the device. This works on both linux and windows (if
// your linux serial device is /dev/ttyS0 for COM1, etc)
$serial->deviceSet("COM1");
// We can change the baud rate, parity, length, stop bits, flow control
$serial->confBaudRate(2400);
$serial->confParity("none");
$serial->confCharacterLength(8);
$serial->confStopBits(1);
$serial->confFlowControl("none");
// Then we need to open it
$serial->deviceOpen();
// To write into
$serial->sendMessage("Hello !");
