Need help on Matrix Keypad Interface Logic
Parth786
Joined Jun 19, 2017
642
I am looking help on matrix keypad. I searched on internet and having difficulty to understand logic of matrix keypad. Matrix keypad use a combination of four rows and four columns to provide button states to the device ( microcontroller). Each key is a push button, with one end connected to one row, and the other end connected to one column.
this is component from Proteus. I was looking datasheet but I couldn't found. How does keypad work with microcontroller. what is basic logic of Matrix keypad?
Alec_t
Joined Sep 17, 2013
15,156
The micro writes a given logic level to each column (or row) in turn and, while the written-to column (or row) is held at that logic level, reads each row (or column) in turn to determine which one or more has that logic level.
Sensacell
Joined Jun 19, 2012
3,787
It's a scanning process, the switches are read row-by-row.
Energize one row, read the state of the 4 columns, then do the next one.
Reads 16 switches with one 8 bit port.
Parth786
Joined Jun 19, 2017
642
any help with example. By seeing definition only its difficult for me to understand operation of keypad. there are 8 inputs connected to microcontroller. 4 column inputs and 4 row inputs My basic confusion is that I don't understand on which logic this keypad work?
EM Fields
Joined Jun 8, 2016
578
Google keypad and click on "images".
LesJones
Joined Jan 8, 2017
4,543
You need 4 bits of one port set as outputs driving say the X axis of the keyboard and 4 bits of another port configured as inputs looking ast the 4 bits from the Y axis.You set one bit of the X axis high the read the Y axis and see which bit is high. If you see a high on any of the 4 bits then you know the button that was pressed. You then repeat the process with the other 3 bits on the X axis high in turn. You will then have tested all 16 keys. With the logic working the way round as I described it you will need pull down resistors on the logic inputs.
Les.
Parth786
Joined Jun 19, 2017
642
Les.
I am referring my diagram.
did you mean like this
X port as output 1234
Y port as input ABCD
if bit 1 is high
1=1 2=0 3=0 4=0
A=1 B= C=0 D=0---------- How to know that which button was pressed
A=0 B=1 C=0 D=0-------- How to know that which button was pressed
A=0 B=0 C=1 D=0---------How to know that which button was pressed
A=0 B=0 C=0 D=1---------How to know that which button was pressed
if bit 2 is high
1=0 2=1 3=0 4=0
A=1 B= C=0 D=0----------How to know that which button was pressed
A=0 B=1 C=0 D=0--------How to know that which button was pressed
A=0 B=0 C=1 D=0------- How to know that which button was pressed
how to know which button was pressed ?
MaxHeadRoom
Joined Jul 18, 2013
30,808
It is all there in the Goodwin example, you take one row low at a time (output) and read each column (input), this detects each independant switch/P.B/matrix.
Max.
