Can you help me i need some information about an electronic devise for a mini door (security) there is in the midle of the chrome cyrcle a green led clygnote on off on off......
If you are truly authorized to get inside this security display then any alarm it generates will be ignored by whatever security service serves that location.Its a security system of this door
Can i hack it by an electromagnitec or high voltage generateur
It wouldn't be a very good security device if you could do that. With respect to a high voltage generator, I'm afraid you might shoot yer eye out, or maybe give yourself a rude awakening.Its a security system of this door
Including a lock such as in the pic you posted?with this voltage can destroy any electronic devise
That will be perfect. Set it to the highest setting. keep your feet wet or dry to protect yourself. Connect yourself securely to a floating ground when you use it. That green light will stop flashing immediately.Yes i have a 400kv high voltage generateur i make it like a spark gape with this voltage can destroy any electronic devise
