Need help making 20 meter magnetic loop antenna
mrel
Joined Jan 20, 2009
189
Hello
Would 5 feet circle using 3/8 soft copper tubing be enough to receive signal on the 20 meter band.
mrel
DickCappels
Joined Aug 21, 2008
10,661
If you tune it, yes. As you might suspect the larger the area of the loop and the more turns, the greater the sensitivity. For that small of a loop at such a low frequency you would be much better off using multiple turns.
The internet is full of examples of small loop antennas. For example:
g8jnj.net/Remotely tuned 1m Dia HF loop antenna for 7 to 29MHz.pdf
http://makearadio.com/loops/index.php
http://www.iw5edi.com/ham-radio/?how-to-build-a-tuned-loop-antenna,118
https://www.qsl.net/pa3hbb/magloop2.htm
And there are plenty more!
recklessrog
Joined May 23, 2013
985
In what sort of environment do you want to use it, i.e indoors, outdoors, loft, shed etc? We, (my old amateur radio group) did some experiments some years ago with mag loops, and came to the conclusion that a half size G5RV with antenna tuner vastly outperformed every mag loop they built for receiving in our location. Properly matched for transmitting, they performed well enough. Having said that, I have spoken to many operators who reckon they are the "mutts nuts" so could just be our guys were unlucky with the designs they tried.
The beauty of the G5RV is you can use it in so many different configurations, as a centre fed sloper, inverted "V," as a "T" and more or less any way you can arrange it.
But, if you are stuck for space, give the mag loop a try.
ccfly
Joined Jun 22, 2008
If is not problematic for you ..
you can build Minkowski fractal antenna in a planar - panel way on a
piece of plastic or card board
dimensions are 30 x 30 cm.
You can use plastic insulated cooper wire and wind 10 turns in fractal shape.
here is a image :
