Need help interpreting the output of this oscilloscope
Creasion
Joined Sep 7, 2019
5
Ok so for a school project i'm working with summing operational amplifiers. Now, look at this circuit:
Ok one thing that stands out is that the frequency differs for both voltage sources, V1 having a frequency of 1kHz and V2 a frequency of 10kHz.
Now when this thing is hooked up to the oscilloscope which measures the value of Vo, what do you think the output would look like?
Formula for the output voltage of summing op amp
VO= -RF(V1/R1 + V2/R2 + V3/R3 +......+ VN/RN)
Where N is a positive integer value.
Now this is what I got as an output:
I just need someone to interpret what exactly i'm looking at here.
Thank you.
schmitt trigger
Joined Jul 12, 2010
2,245
Channel 1 and 2 have different vertical scales!
If the yellow trace is the output, it looks correct. But set the vertical scale to the same V/div.
SamR
Joined Mar 19, 2019
5,538
Not sure what you are doing with the cursors, but everything is there under Meas f, phase shift, Vpp.
Creasion
Joined Sep 7, 2019
5
Glad to, but you have to tell us that.
You have one output and two traces, so what are the two oscilloscope inputs connected to?
The two oscilloscope inputs are connected to r1 and r2.
What do you mean by traces.
Also where are the inputs and outputs on the screen?
JoeJester
Joined Apr 26, 2005
4,390
The yellow one is trace 1 and the green one is trace 2.
Your INPUTs do NOT state the peak or rms amplitude of their respective signals.
At what point on R1 and R2 are the probes connected?
What do you expect for an output based on your calculations?
