Need HELP! I'm a Electronics Amateur -Indicator Liights in Charging Circuit
Viesuliss
Joined Mar 6, 2017
So im trying to do a system where where by putting a Source of DC electricity#1(The charger), it charges the other DC Source#2 ( Accumulator in real life), so the accumulator is charging, and the left light is on( Seen on the screenshot). When there is no #1, i would like the left lamp to turn off, not stay on from the #2 source, is it possible to be done? There must be a way, and i hope you understand me!
dl324
Joined Mar 30, 2015
18,465
Welcome to AAC!
Sounds like you just need a diode. What are the voltages for the sources?
Throw out the schematic. It makes no sense at all.
Cropped image for convenience:
Dodgydave
Joined Jun 22, 2012
11,395
Put a resistor in series with the charger and battery, and put an led across the resistor, so when the battery is charging the resistor will have a voltage drop across it,
or put a diode in series with the charger and battery, and put the light across the charger.
Viesuliss
Joined Mar 6, 2017
Welcome to AAC!
As i said, i'm complete amateur and only understand the basics. All the components are 12V, since i want to do this inside a car.
Should i really make a schematic? It's all Basic, and i don't even know what the gates do.
