Need help identifying part on Power Supply (pics)
Swellengear
Joined Oct 31, 2024
Hi guys,
and greetings from sunny South Africa.
I have an older power supply, which as soon as a load is applied, the voltage drops. I have opened it up, and found a blown cap,
as well as a blown/burnt transistor. I cannot make out the markings, so if anybody has any insight, it would be much appreciated.
I have searched the web for a circuit diagram, but no luck. Electronics is not my forte, but I'm willing to have a go! Much prefer to
repair than replace.
Thanks in advance, and pics below.
Offending parts removed: (Q3 & C3)
Component still in situ:
Ian0
Joined Aug 7, 2020
13,299
There's no voltage on there above about 25V, so almost any transistor will do, once you determine whether it is NPN or PNP. Do you have a circuit diagram?
Swellengear
Joined Oct 31, 2024
Thank you boostbuck! I think you may be on to a winner, certainly looks correct, and from the markings on the board, I do believe it to be a PNP. I will grab a replacement, and see what happens.
