Need help identifying electronic part
bertus
Joined Apr 5, 2008
22,928
I played a bit with the intensity levels and could see a bit more of the part:
It looks like a 25 Volts capacitor.
Is there more text on the other side?
ian field
Joined Oct 27, 2012
6,536
looks like some sort of part number 3360. I thought the same . Thanks for cleaning up the image.
Can you photo the ends?
What markings that can be made out suggest a capacitor, but the appearance of the damage - not so much.
There are/were VDRs (a type of MOV) in that sort of voltage range for shunt regulators where accuracy is way down the list.
GopherT
Joined Nov 23, 2012
8,009
Mount your part and camera on a stable surface and use the time-delay shutter so you are not touching the camera whe the image is captured. Also, add some more light. It is amazing the clarity you get without the ever-so-slight movement of a human hand.
Aleph(0)
Joined Mar 14, 2015
597
FWIW It appears to be a 'paper' dielectric capacitor - That said, it has been my observation that the 'package-style' of the imaged device significantly predates the 1980s?:confused:
Best regards
HP
HP I say based on pic of damage in post 2 it's probably tubular ceramic cap? Anyhow I agree that pic needs scale to be more useful:)!
