Hi, I have a dishwasher motor I am trying to use on a project. The motor isn't a standard 2 wired ac motor but has 4. There is a big start capacitor (I assume) on the side. A blue wire from it goes through a relay and back through the pink wire pin 4. The connection is NC, so power flows all the time. I did some testing and applying 110 to pins 1&3 which are nutral and power on the board, and nothing happened. So I touched pink and blue wire and it fired up. And once going I could disconnect it and the motor will still run. So I wired a little box with a momentary button and I would just hold it for a few seconds and it would fire up, thought I got it, but I go to pump water and I'm not able to let go of the button or it will stop. I figured the computer disconnected Power once going. But under load it doesn't seem to work that way.
Can anyone tell what the symbols Hi1, Hi2, Ho mean? If I wire the pink and the blue to be constant is there and issue? I Just don't understand why these 2 wires, pink and blue arnt connected together but through a relay, so for some reason the computer needs to disconnect it. I don't think it's to turn the pump on and off as the power that goes to it is controlled through a different relay.
Hopefully somone can shed some light on this? Thanks Jeremy
