Need help. 8 bit binary to bcd conversion
Ian0
Joined Aug 7, 2020
13,306
Do you have an ultra-violet light EPROM eraser? I presume you don't! Then avoid the 27xx
IF you don't need to go beyond 99, or you're happy with a 2-chip solution, then AT2816, because it can be erased by your programmer.
If you want a single chip solution then you'll need something with 16-bit wide outputs such as the M27C4002 as @dl324 suggested.
royashley99
Joined Nov 20, 2021
47
I'm going to be using two 74HC258's to make a 8 bit adder and I want to make a circuit that I can connect to it to display the binary output on a 3 digit 7 segment display
Ian0
Joined Aug 7, 2020
13,306
I thought you would ask that (see post #5)!
With a 2816, you can go straight from 8-bit binary to 7-segment display.
Use A0-A7 to input your binary number.
Connect a 4017 to O1 to A8 and O2 to A9, connected so it counts to 3 - this is your digit multiplex counter. The 4017 outputs also drive the anodes of your 7-segment (common anode displays) O0 to units, O1 to tens and O2 to hundreds. Connect a clock to the 4017 of at least 200Hz.
In addresses 0-255 program the 7-segment outputs of the units digit .
In addresses 256-511 program the 7-segment outputs of the tens digit
In addresses 512-767 program the 7-segment outputs of the hundreds digit.
Buffer D0 to D7 with a 74HC541, because the EPROM probably doesn't have enough output current to drive the display, and connect it to the segment (a,b,c,d,e,f,g) connections of the 7-segment display.
LesJones
Joined Jan 8, 2017
4,544
If you are planing on using a multiplexed display a variation on the EPROM idea would be to connect the 8 input bits to address lines 0 to 7 and a multiplexing counter (which counted to 3 or 4 for the multiplexing.) connected to address lines 8 and 9. You would only use 4 data output bits from the EPROM and connect these to the inputs of a 7 segment decoder.
So each multiplexing time slot only needs to output one digit. So each of the three areas of the EPROM (Selected by A8 and A9) would only contain the information for one digit. (Units, tens, hundreds.). You could even dispense with with the 7 segment decoder if you used 7 output bits from the EPROM and programmed the EPROM with the 7 segment patterns rather than the decimal digits.
Les.
Ian0
Joined Aug 7, 2020
13,306
Les.
Great minds think alike!
dl324
Joined Mar 30, 2015
18,490
I have been told that the 74ls185 was just that internally.... Eprom programed to output on the count on the input..
AFAIK, no one ever made an LS part. 74184 and 74185 were derived from 7488 PROM. National Semiconductor and TI stated this in their datasheets.
dl324
Joined Mar 30, 2015
18,490
Cheers for that.... I thought I heard it somewhere..
Funny though.. A quick google lists 74LS185...
I started using 32x8 PROMs in the mid 70's and there were no LS parts. When I searched, I only saw one URL to it and you had to join to download the datasheet. I passed...
dl324
Joined Mar 30, 2015
18,490
Where would you purchase the 74LS185's
You can make your own using 8x32 PROMs; 8 bits would require 3 of them. If you were tempted to go that route, you should just program an EPROM with a 16 bit output. In the thread I referenced earlier, I programmed one to do 4 BCD digits.
