hmm okay but why 18.6K ohms? I don't get that part. I will try your circuit tmrhi,
The problem is that the Gain of U2 is not just simply set by R5/R6 , because R6 is connected to oV via R4 which is in parallel with the diode resistance in series with the output impedance of U1.
So as the voltage on U1 changes, so does the diode resistance, [ which is not a linear change] and therefore the Gain of U2 changes.
E
EDIT:
Try this asc file.
thank you very much.
