Sorry if I'm frustrating you, I am lacking confidence you're putting things the right way around. I don't mean to speak down to anyone, so if you take offense at this - my apology. I'm not here to insult anyone; I just want to be absolutely certain you have this the right way around.
Based on your description you are saying the dashed wire is the negative lead from the power supply. According to the drawing you drew you have the diode going from positive to negative, creating a short circuit. The relay wont work, the diode will burn out and possibly the supply will be damaged. And quite possible the floor switch will also be damaged. The drawing I've attached should make it very clear as to which way the diode goes. Beyond this I'm not going to be able to help you. By now you should have enough information to handle this correctly. Again, if this comes off condescending - I apologize.
