Well I took your suggestion and double checked all the connections on the inside. I had already cleaned and reassembled everything on the inside so this time I pulled the covers off the clamps and it looked like the negative cable had been arcing where the wire was crimped. I took it apart, cleaned it and cut the wire back to get a good clean end and now it's showing the same voltage as before with no load but I connected it to my El Camino and turned everything on inside and now the amp gauge moves, but in the opposite direction. The positive lead comes off the rectifier plate and goes through the amp meter, does it matter which direction it goes through the meter? I forgot to measure the voltage with it under a load but it gives a big spark when you touch the leads together on the 2 amp setting.
