NanoVna measuring Q of inductor
Zeeus
Joined Apr 17, 2019
616
Wish someone will assist
Measuring the Q.. Xl/r . Also, the nanoVna has Q function
But my coils all give low Q.. Less than 70 and can not understand why.. The coils are from kitsandparts
Have used wire gauge 24 and 26.. still can't get high Q at 7Mhz...not even high from 1Mhz to daylight
What can do?
DickCappels
Joined Aug 21, 2008
10,661
Along with the useful information posted above, for the highest possible use many small diameter separately insulated wires in parallel instead of solid wire. This reduces the eddy current losses within the copper.
ericgibbs
Joined Jan 29, 2010
21,573
hi Z,
Please post your actual calculations, your numbers look incorrect.?
E
Also what is the inductors internal capacitance.?
bertus
Joined Apr 5, 2008
23,006
In the posted PDF, the Q of the T68-2 is given on page 14 in the lower graph.
On page 16 the Q of the T68-6 is given.
Bertus
Zeeus
Joined Apr 17, 2019
616
hi Z,
E
The calculation is right E..The nanoVna also has a Q function.
Didn't check the capacitance... now, will use the graph to check things out
Although i know someone that had a Q of about 160 using T68-6 at 14 Mhz... Mine didn't work
DickCappels
Joined Aug 21, 2008
10,661
If you were able to double the frequency without changing anything you would also double your Q, except we know that there is more than just resistance and inductance at work here.
Zeeus
Joined Apr 17, 2019
616
lol...oh really? the resistance also increases with frequency but at a slower rate
The nanoVna also has a Q function.. Same reading with calculation Xl/r
ericgibbs
Joined Jan 29, 2010
21,573
hi Z,
If you are measuring the inductors laid flat on that what appears to a copper clad PCB, which is used as a ground connection , try moving the inductor away from the copper surface, then retest.
E
Zeeus
Joined Apr 17, 2019
616
hi Z,
E
No...can't do that... I even tried without the copper clad..same thing
From the smith chart, it has no capacitance
T68- 6...even from 1Mhz to 10Mhz... The Q is not above 75
Someone please solve problem for TS please
but i think, problem lies in your response on ground
