Naming for battery voltage supplies
Dritech
Joined Sep 21, 2011
907
Hi all,
When having a circuit powered by battery, which are the best abbreviations to use for the supply lines ? Should I use the GND symbol when a circuit is powered by a battery (as shown below)?
In the example below, for the output terminals of the battery, should I used Vdd for the 6V and Vss for the 0V instead of Vs and GND?
For the output of the switch (which can toggle between 5V and 3.3V) is Vreg a good abbreviation to use?
SamR
Joined Mar 19, 2019
5,519
Vs and Gnd/GND are fine for batteries, Vcc and Vdd came from transistors to indicate Vcommon and Vdrain. Even POS/+ & NEG/-. YMMV
ericgibbs
Joined Jan 29, 2010
21,525
hi Dri,
When using just the 'V' letter, I prefer to prefix the letter with the '+' or '-' symbol, it makes the polarity clear to the reader.
Also for battery I use +Vbty or -Vbty, so it is obvious that it powered from a battery source.
eg: +12Vbty..
Some use Vss or Vcc, Vdd or Vee , ie: transistor's, fet's
Gnd or 0V, usually refers to the measurement reference Node, I only use Earth for an actual connection to physical Earth
On your switch diagram I would use Vin, Vo1, Vo2.
E
Audioguru again
Joined Oct 21, 2019
6,826
Your voltage regulator has no part number. A 7805 or an LM317 needs a minimum input voltage of 7V but your battery is only 6V when new and drops to 4V during its life. For a 3.3V output the input must be 5.3V or more.
"Low Dropout" regulators work with input voltages near the output voltage.
dl324
Joined Mar 30, 2015
18,446
You shouldn't use Vdd or Vss unless you're using CMOS, where those names are commonly used for power and ground, respectively.
No. You have two voltage regulators and Vreg would be ambiguous.
Unless your 5V regulator is an LDO, 6V isn't high enough for it to regulate.
sparky 1
Joined Nov 3, 2018
1,218
Some will read this and not be happy, to others it reads ok.
There is a decision when to throw away a AA battery for example the battery drops to 1.1V
then 6 each AA make the minimum Vbat total of 6.6Vdc. A 5V LDO and 3.3 V regulator would use the 5V LDO voltage as the limiting factor. I read your schematic as a missing batteries error. Others would refer to the actual board and say yep it's a 5V step up converter not a standard 5V regulator what a lazy. Lots of different words and abbreviations and some will use something different just to be different. So it is what makes sense to you and and those who will need to refer to a pictorial schematic. It is a good topic about using standard abbreviation or naming.
