Name your favorite tools thread
Paulo540
Joined Nov 23, 2009
191
This isn't mean to be a "ford v. chevy" debate, moreso just curious what you all use as your main troubleshooting and repair tools.
Meters
Scopes (Pawn shop Tektronix handheld 60mhz, cal'd)
Solder Irons (Oki/Metcal PS-800e - love it, assemblers put 1000s hrs no faults)
etc.
Also, whats the best 'sleeper deal' piece that you bought just cuz it was cheap or as a backup, but ended up as a mainstay?
For example, I love my 20$ (on sale) crafstman 82139 dmm. It does almost everything, and quite accurately I must say (several main functions, including TC been tested against calibrated equipment) Had it for several years, blown a fuse or two. Has it's limitations but rock solid.
beenthere
Joined Apr 20, 2004
15,819
I get the warm fuzzies over a 1/2 oz ball pein hammer. It let me make micrometric adjustments to accomplish setting up drive blocks in 18 Potter tape decks in a matter of minutes per drive. The spec on the field change kit said 8 hours per installation.
Can't live without my Fluke 23 DMM. Or my Weller W-TCP soldering station.
kbupnorth
Joined Sep 8, 2008
4
My Leatherman. Use it about 10 times a day at work. I'm lost without it.
Also my 30 year old P-38 can opener. Function and simplicity.
Wendy
Joined Mar 24, 2008
23,797
Definitely my DVM. Make and model isn't really important.
Followed by (in no particular order) protoboard, power supply, oscope, and leads for the equipment with removable grabber clips. A second DVM isn't bad either.
Followed by a decent set of wire strippers (T Handle), needle nose pliers, wire cutter, and decent screwdrivers.
Did I mention my computer?
t06afre
Joined May 11, 2009
5,934
I have an old and cheap Weller solder iron. It is 25 years old. I pimped it up with a long life tip, and an isolation transformer. Somehow it settled to have the correct temperature spot on. For my hobbyist soldering this is my favorite tool. ;)
hobbyist
Joined Aug 10, 2008
892
Proto boards, DMM, resistor sub box, audio signal gen., oscilloscope, variable benchtop power supply.
Then the run of the mill soldering equipment.
I seem to have gotten a collection of multimeters, because the electronics suppliers kept putting them on sale, so I bought them just for the great price deals.
Wendy
Joined Mar 24, 2008
23,797
At bedtime a man gives his wife a couple of aspirin.
"I don't have a head ache" she says.
"Good," he says, "now that we have that out of the way..."
