Already ordered the complete PCB to replace it. Problem is it's going to take 45 days for delivery from China. If I know what the part is. It could be here in a couple of days and hopefully fixed.You could replace the original component, just make sure that you get it the same way round as it appears to have a polarity stripe.
Possibly a diode or electrolytic capacitor.
Time to use a meter. Try diode test and try resistor test, then reverse the leads.With a single stripe like that I guess it could be a diode, but the color looks like a resistor. No clue as to the resistance value.
The TS already told us that they lost the part.Time to use a meter. Try diode test and try resistor test, then reverse the leads.
There are a few on the board. The others look identical. I only lost one off the board.The TS already told us that they lost the part.
They read 0? Do you mean 0L?all gave zero when reversing the multimeter polarity.
Ultrasonic Parts Cleaner? | General Electronics Chat | 8 | |
| J | Power supply with LM317 Advices Needed - Part 2 | Power Electronics | 18 | |
| M | Tumble Dryer not heat, replaced most parts! | Technical Repair | 43 | |
| B | The Harvard air hockey PCB repair part deux | Technical Repair | 6 | |
| K | Name of this?? | Datasheets, Manuals & Parts Identification | 6 |
