ebeowulf17
- Joined Aug 12, 2014
- 3,307
It's really hard to tell, but it looks on that picture like you've run a wire from the "Bat" pin to a 5V regulator, which then runs through the resistors to your trinket and motor controllers?
Putting aside the question of resistors for a moment, you should be able to eliminate that separate voltage regulator by connecting a wire from the "5V" pin to the resistors and on to the trinket and motors. The power boost board already has a 5V step up boost regulator on board specifically for this purpose.
Finally, and this could turn out to be the most important question: when you disable the power boost to turn off the circuit, how are you doing that? It looks in the picture like maybe you've got a jumper wire between "Vs" and "EN" or maybe GND. How exactly do you connect those three pins for normal operation, and when you want to turn the circuit off?
